Hi there, today our oven was on when the electric tripped. When reset the oven would not heat up, the thermostat light stayed on although the fan worked. Classic signs of a failed element I believe. When I removed the back plate there are no visible signs of the element failing, it looks in reasonable condition. I have not removed it as it looks like the screws into its mounting plate come in from the back of the oven so I will have to get it out.
The only thing that concerns me slightly is that I read somewhere that an element failing could actually be caused by a faulty fan motor. Now for some time our fan has taken about 10 minutes to fire up once the oven has been turned on, I'm sure it used to come on straightaway - should it come on straightaway? Once it starts up its ok so I'm wondering if this is just a red herring. It looks a little brown but rotates easily enough. Ironically now the element is broken the fan does come on straightaway.
Any advice greatfully received.
Thanks.
Thanks.
