Breaking up Concrete Drive for Block Paving
22 Nov 2005
London
Hi All,
After the relative success of laying my first patio - 40m2 of Indian Stone, I now want to have a go at doing our driveway.
I'm just at the planning stage at present, not 100% sure of if, or when to tackle it!! Is block paving easier than slabs as you lay onto sand rather than a mix?
My main question is, our current drive is 4-6" of poured concrete, as and when I break this up can I re-use it as a partial sub, meaning I's need less MOT Type 1?
Just trying to cost everything up before starting!
Many thanks!
You wont break the concrete up small enough to use as hardcore.
You will need a breaker, or if its a large area, mini digger with a breaker fitted.
Thanks, I was going to hire/buy a breaker. The drive is about 30' long and 10' wide, already done some of it with an SDS when I had to put a new soil pipe in, broke up fairly easy......
He could hire a crusher.
So it's cost of that, vs cost of paying to have the old concrete taken away + the cost of buying hardcore.
Screwed - let us know if you find out how that equation balances....
Mmm, thanks, I'll try and do some sums!! With regards to laying the blocks, we're not having a pattern, going for irregular sized blocks, in my mind this seems easier rather than trying to lay the same size blocks in say a herringbone pattern. Am I still wrong in thinking this is easier than laying slabs, I have read the Paving Expert website obsessively a number of times and still think I can do it..........
There is less skill required to lay block paving but more basic knowledge and setting up.
Once you have your screed rails in it all flies down compared to mortar bedding. its also more compliant in the sense that a vibrating plate will help hide any high blocks etc.
A pattern is not in any way difficult. Laying in stretcher bond is fast and easiest but herringbone is better for a driveway as its more stable under lateral loads.
This is not an issue if your drive is straight with no turning.
Assuming its not super thick a 14lb sledge hammer is much faster than a breaker. Hard work though
Yeah I have.........but the Mrs wants it to match next door!! Seems as though as long as I get the edging set right, the rest should be pretty easy......
Grab a Titan breaker from Screwfix for the concrete removal. It's only £150 or so and worth every penny.
I removed my front and rear garden poured concrete bases (each approx. 30'x20') and decided to save money by using the 'good' concrete as hardcore. 4 days and two very used sledge hammers later and I had 6 tonne bags of MOT1 sized concrete stones ready for use.
Saved about £260-300. Would I every do it again? No chance! It was friggin torture. Just go buy the MOT from wickes. With free delivery that was the cheapest available when I did the work last summer. Also, buy through Quidco and get a few £pounds back.
There's quite a few on eBay for even less. Probably the sort of tool people buy as they don't need it for long, and it works out cheaper to do that and sell it afterwards than hiring.
But I think I'd be tempted to look on eBay for a far superior Bosch/Hilti/Kango, again to sell on when finished. TCA would be higher, but TCO low.
I've had a Titan (actually an Erbauer, but they're one and the same) for 3 years and used it on loads of projects. It's never missed a beat and is surprisingly powerful and robust.
I wouldn't bother buying a 'better' branded one if you're just planning on selling it afterwards. If it gets damaged you'll lose a heap of dosh. And if you buy a really cheap one off eBay (especially if you plan to keep it) try and make sure it comes with a warranty. The screwfix one has a 2 year warranty, which could just come in handy.
Check out the customer reviews. Plenty of people surprised with just how good the tool is:
http://www.screwfix.com/p/titan-ttb280drh-15-5kg-breaker-230v/67819
Yeah I'd planned on buying one of these, got the Titan SDS and that was fantastic for knocking out the drive for the new waste, especially for the 50 odd quid it cost me. I was even looking at buying a whacker plate on EBay, that way I could do the drive in sections rather than trying to hire one and get it all done in a weekend. Thanks for all the advice, certainly feel confident in taking the project on now!
Haha, that's exactly what I did. I bought a medium heavy one for £170 odd to compact the rear garden hardcore last summer. The job was a big one and was split over a few weeks. Only wish I'd bought the whacker sooner as it would have saved me even more cash when I did the front drive a couple years earlier.
The only issue is storing it. I'm not selling it as I'll only regret it when the next job comes-a-calling out of the blue.
All the best with your project.
