As has been said, we could do with a photo, so as to be sure what it is. This could be important - see below.My present set up has a RCCB (i think that's what it is) .... Black box with red test button & sliding off/ on switch. This is between the meter & the fuse box.
I imagine you're referring to the housing for the electricity company's ("DNO's") fuse. Again, if you want a definitive answer, include this in a photo!There is also, before the meter, another black box with a seal on it but no switches - what would this be for?
If the 'black box' is a modern-type ('current-operated') 'RCD', then a new CU would give you no additional protection - merely added 'convenience' in that it would contain more than one RCD, so that one fault resulting in a trip would not 'take out' your house's entire electricity supply. If the black box is not an RCD but, rather, an old-fashioned Voltage-Operated Earth Leakage Breaker (VOELB), you ought to arrange to get it changed for a proper RCD as a matter of some urgency (if you don't decide to get a new CU), since VOELBs are no longer acceptable, and do not provide adequate protection (which is why we need a photo!). I'm a bit suspicious since, whilst VOELBs were often black, it's rare to see black modern RCDs.Also, what extra protection would a new circuit breaker unit give me over staying with the existing box fitted with or without plug in mcb's
