Wylex fuse box
1 Oct 2005
London
Hi all,
My house has a Wylex fuse box with 6 fuse carriers (2 x 5 amp and 4 x 30 amp) - I'm looking to convert these to mini circuit breakers that just plug into the fue holder.
At the end of the line of fuses there is the fuse box switch and then a separately covered single fuse holder, that look different from the others. I figure this is a master fuse for the whole fuse box.... or is it.
Any help would be greatly appeciated.
Roy
roytom said:
Hi all,
Roy
its a 45A fuse holder for a cooker/shower. should be green. altho i think it can be changed for a lower rating. the only fuse protecting everytihng is the service fuse
Nijinski001 said:
I thought only Superman had X Ray vision?
Not quite, its because he has experience (like myself) and has'nt just done a 5 min traing course ;)
What's that supposed to mean?
Why have you signed in under a question mark?
its a popular type of board. ive seen hundreds. and on the type he has described, the fuse to the right is for cookers/showers. any good electrician will know this.
as for the question mark, i have no idea. youll find out if he returns
Andy
My comment wasn't aimed at you. I was naffed off at the guys implication that I had only taken a 5 minute training course. I may not be as experienced as a lot of guys on this forum but I have over 20 years of domestic wiring experience but have only just gone official this year with a level 2 DI certificate.
Regarding the Wylex 45a fuse I have also seen it used for other things such as external supplies to sheds etc. It may not be right but I've seen it never the less.
Cheers
Yes (on further investigation) the separate end fuse (with its own cover) - thats the lone fuse to the right of the switch, is a 45 amp rating and is exclusively for the electric oven/grill unit - nothing else.
The fuse carrier is slightly different from the others in that the connection pins are two spayled metal stips rather than the one thick pin only on the other fuse carriers. Does this mean that I cannot use a MCB in this fuse socket as the connections will not fit?
Also I think just a 30amp rated MCB would easily be enough as there is not an electric hob involved in this only the built in oven/grill.
Many thanks to all those who replied before.
Regards, Roy
With it being 45A it will most likely be a cartridge fuse, whereas the other fuses up to 30A may be rewirable fuses. There is no reason why you can't change it for a plug in circuit breaker. What is the Kw rating of the oven?
As Andy replied !
Why have you signed in as Nijinski001 ?
