Hello
I'm in the middle of decorating what used to be my parents' old home (now mine) and would like to remove a telephone socket from a bedroom that is no longer needed.
I'm aware (basically from reading posts on here) that it isn't just a simple case of cutting the wires off at the wall and plastering over the hole and that the 'master socket' comes into play ... but that's where my knowledge starts and ends
Here are a couple of photos of the socket in the bedroom I want to remove:
[/img]
However, when I've gone to look for the master socket I've discovered two, side by side, in the front room (where my parents installed the first telephone, back in the early 80s).
The older of the two sockets is practically hanging off the wall, but they are both wired up although haven't had a telephone attached in many years as my parents got a socket installed in the living room years ago and had just used that one.
Here are the images of the newer of the sockets:
and the older master socket:
Please note that I didn't pull the bedroom socket off the wall, that happened when the walls were being re-plastered.
From the photos, is it straightforward what I should do to remove the bedroom socket, or should I just bite the bullet and get a telecoms guy out to do the job?
Thank you.
[/img]
Thank you.
