.What I would reccomend is a small unvented cylinder, with vaillant controls. Which means you could use a 615 (assuming 15kw is enough for the heating load) witch will switch between heating the cylinder and rads separately meaning you have the 15kw output focused fully on one or the other demand at once.
What we usually recommend, but a decent combi is often enough when you get down to brass tacks.
