Hello
I have an unvented thermal store, supplied by an oil boiler, wood stove, solar panels (when I can afford to have them installed) and an immersion heater. The immersion is powered from excess electricity from photo-voltaic panels, so it is FREE
The immersion is fitted with (of course) a Becker 7" stat preset to 65C. This is fine, but as the year progresses it cuts out pretty quickly. The oil fired boiler is set to about 70 C, the lowest the plumber said was viable (and to be honest, it would have been better if it was a bit hotter in the middle of winter). So I am balancing the hot water and heating demand to try and keep the store cold in the morning, so the immersion heats it up as much as possible during the day. Otherwise, the boiler heats it to 70C and the immersion does nothing even if its sunny all day.
Obviously I want to get the most heat out of the FREE immersion to save on burning oil. What I think it needs is a stat set to (say) 75 or 80C, to allow the immersion to do more work and so save me money on burning oil. Then there would be less balancing, and fewer cold showers when I get it wrong! Even when I get the solar panels, the immersion would be 'topping up' the solar making it more useful for longer in the year.
Can anyone recommend a 7" stat, including a re-settable overheat cutout, which is adjustable up to this sort of range? Do such things exist? Can you get separate re-settable overheat trips which I could put further up the store (probably on the vent pipe at the top) and use an adjustable 7" stat? Is all this against the required standards anyway?
All help gratefully received.
-Pete
-Pete
