Hi there,
I'm just wondering if i should be concerned and if anyone has any ideas on how to ease the problem? It's a fairly tight gap between the cable so it would be tricky to place pipe insulation. Not only that, but I read somewhere that polystyrene shouldn't come into contact with PVC cables anyway
(Thermoplastic (pvc) sheathed cables including thermosetting insulated with thermoplastic sheath e.g. lsf, must be separated from expanded polystyrene materials to prevent take up of the cable plasticiser by the polystyrene as this will reduce the flexibility of the cables.")
Recabling is really not something I want to get involved in doing.
Is there an ideal fix that I haven't thought if? Don't really want to leave the cable like this for obvious reasons. At least one of those two pipes is a hot water pipe by the way.
Thanks.
P.S. Whoever did this needs bladdy shootin'!
