Because you're trying to be a good citizen?PS I need the missing drawings as these need to be sent to the council.
Don't pay the balance until your local planning office has checked and agreed with his calculations. If he thinks he's right then he's got nothing to worry about.. seems very expensive for calcs and drawings!!!![]()
And as someone once said, a verbal contract is not worth the paper it's written on.There is no written down contract with the original SE just a spoken arrangement.
The missing drawing should how an existing rsj should be supported as present its supported on the wall that was built same time as the house approx 70 years ago so no lintel or stone mentioned under the area to be supported also its at an angle of 45 degrees so the rsj/steel is at 45 degrees to the original brick wall.
Yes I agree, but you're leaving the crucial bit out of my post. I have no problem with a builder querying something. But when that query is checked by the SE and the SE confirms the design is correct, what, at that point, is leading everyone to think the SE must be wrong and not the builder? I'm not saying an SE can't be wrong. I've come across plenty of them myself. But once an issue had been raised it would be a pretty stupid SE that allowed a major error run without being 100% sure. So something's still not right here. How does the builder justify his comments. Did he carry out calculations or is this a hunch?"I'm still not getting how the builder is qualified to question the SE"
It's called experience.
SE's make some real over engineered/under engineered monumental cok ups.
SE's designed this...
https://www.youtube.com/watch?v=j-zczJXSxnw
Ever seen an 8' deep girder bend like rubber?
Now you have!
Here's a question for the SE;s on here....
If you pour 20 cubic meters of wet concrete (about S3 slump) into a 13.3m long x 3.6m high retaining wall in less than 50 minutes and the wall is tapered 240mm narrower at the top, will the force drive the Peri formwork upwards releasing the concrete?
Now you have!![]()
