I decided to replace my fully functional T6360 room thermostat with a more efficient CM900 automatic digital thermostat. After several hours and a couple of blown fuses, I'm a bit stuck. I have an Ideal boiler, which has its standard controller. That controller is set to an auto program for the hot water. The heat is set to constant, and controlled by the T6360 in my entry hall. The T 6360 had the following connections: Live to connector 1, switched neutral in to connector 2, switched neutral out to connector 3, earth to earth. As I said, everything worked fine, I just wanted something automated. The CM900 is hooked up as follows: Line to A, switched line out to b, switched line in to C. Now, my heat won't turn off. if I switch the neutrals around, I blow a fuse. I have it programmed for 20 degrees at 5 am, and 18 degrees at 9 pm. It does the same thing in manual mode. Can anyone help me out?
Thanks in advance.
Thanks in advance.
