Just as a follow up: My opinion is that you would be wasting your money on a solution which is not guaranteed to work.
If you read some unbiased studies as to the benefits on PIV; many conclude that there is only a benefit in the very worse case scenario i.e condensation dripping down windows and black mould in every room and all over the place. These were usually poorly built/designed council houses from the 60s/70s with very poor heating provision and insulation.
In properties with small amounts of mould/damp they [PIV] did not have much of an effect.
In any case, to ensure PIV works effectively you would have to do all the things that would probably solve your condensation problem for free!
You have to ensure air can flow around the property, keep internal doors open. Reduce the amount of moisture you create or remove it as close to the source as possible. Use heating more effectively etc.
From experience, homeowners with damp problems seem to like to believe the worst case scenario first and attempt to fix the problem by throwing cash at it in the misguided belief that it will fix it.
In the majority of damp cases, the solutions are usually either free (changing living habits) or quite cheap.
The problem is people do not like to believe/admit that they are the cause of the problem they are trying to solve, nor do people like to change they way they live.
This is usually magnified when the property is lived in by tenants. They just want to live in the property. If there is a problem with the property, it is the landlord who needs to fix it. You as a landlord do not have the ability to change their living habits. As it is not their own house, they are less likely to change their living habits to prevent a problem.
I would print of a guide such as this and explain to them that they need to look at how they use the property.
http://www.bolton.gov.uk/sites/documentcentre/Documents/Condensation and Mould.pdf
Ensure that the extractor in the bathroom is powerful and has a humidistat which will insure it will not turn off until the humidity is at the correct level. If you can, install one in the kitchen too! Ensure your tumble dry vents outside! If a condenser, put an extractor fan in that room as well.
