Time to do the Google search: 15s[Maybe you have more time on your hands than I do.
Time to create the post asking the OP: 45s
What a bizarre thing to do. Why go to all the effort of opening up the machine and replacing the flex rather than just not connecting L2 & L3 at the supply end? Nothing is done inside the machine to link L1-L2-L3, so all you're doing is not supplying anything to the L2 & L3 sections.https://www.youtube.com/watch?v=6trQR5e4baU
I think it can be either.so you reckon is a single phase dishwasher?
If you're in the habit of buying industrial appliances you should learn more about how they use single- and multi-phase supplies in the various countries into which they are sold.Yes, it's industrial one and I had the exact model before.
Maybe they tell you to do it that way because otherwise you won't find out that they've got all the colours wrong, and if you just fiddled with the supply end you'd end up only powering the L2 connection in the machine.![]()
Indeed, but how would you know which was L1, L2 & L3?I know what you mean,you can just not connect L2 L3 at the socket end.
Then you must have an electrician to install it for you. Ask him to vet any possible purchases.i'm afraid am not in habit of buying industrial appliances,i run a coffee shop which need a dishwasher.
Err--- you don't have or use an electrician, do you.Thank you john for your replies,
Yes the same model .it was plugged to normal socket.
the socket started melting after a while. Then I swapped it to male/female 20a as a converter between the dishwasher socket and the 13a socket.
I don't know whether was right but it worked
[quote
Are you aware that that's a criminal offence in your case?
No, to not be competent to do electrical work.what not to have an electrician![]()
i think and i'm only guessing,that machine on youtube is new and changing the whole flex looks neater and new.
i've used the link to show that i got different answers to my original question,whether the dishwasher is single phase?
regards
Sam
