combination hot water cylinder, stuck drain off
27 Jan 2014
Essex
I have a h/w cylinder with a side entry immersion. The immersion seems to be tripping the electrics. The drain cock washer has broke off and is stuck therefore I can not drain the cylinder to change the immersion. obviously with it being side entry I do not have the option of removing immersion and siphoning. The drain cock is at the side and tight to the wall so I can't even free the washer then quickly put the cock back in.
Any smart ideas? Would heating up the drain cock with my gas gun do me any favours? maybe melt the washer
Empty the system as much as you can then undo the top connection on the cylinder and stick a hose in, then syphon till you reckon the level of the water is lower than your immersion heater.
it is a combined hot water cylinder. Cold mains fills the top and feeds the h/w cylinder below. It is so tight to the ceiling that I cant gain access to feed a hose down to siphon it. The immersion is side entry and the hot water draw off is obviously on the side on the lower part of the tank. If it was as simple as disconnecting the top connection and siphoning then I wouldn't be on here. So..... any ideas on the drain cock?
Looks like your the clever one mate :roll: I am sure you will figure it out.
How about
Turn main off to tank, open hot taps, towel or wet vac around hot draw off, undo connection
Feed in hose
