If you ever find a definitive answer, please do let us know!I really must find out exactly what function the functional earth provides.
That's certainly the story that one usually hears - but, unless it's just intended as an 'additional feature', causing the device to operate if the N goes open-circuit (which I very much doubt), it seems to be addressing a 'vanishingly improbable' scenario - namely that a 'good reason' for the device to trip should arise at the very same time that the neutral is open-circuit! Or am I missing something?The obvious one is as a source of "neutral" to power the trip mechanism if the real Neutral goes open circuit leaving only Live at the RCBO.
Is that materially different from the above? If the supply neutral were to literally go o/c, in the presence of any connected loads at all, the potential of the neutral of the installation would rise to line potential, wouldn't it?But it may also be intended to enable a trip when Neutral is floating to far from ground potential.
