Yes. The maximum load of this appliance is 10kW.Do you know some way of specifying a minimum required supply other than by specifying a minimum fuse/MCB rating?
A maximum will be to protect a supplied flex.As I said before, there may also (but not necessarily) be a requirement for a maximum OPD for safety (in which case I see no alternative but to quote minimum and maximum OPD ratings
Not if they are foolish enough to state a minimum opd size.It's all very well citing the instruction that installation should be undertaken by a competent person/qualified electrician - but, at least until some same next year, (s)he is, strictly speaking, constrained by whatever the manufacturer may 'instruct'.
That should be ignored now.
