I need some with fitting a 2 way dimmer and 1 way switch in kitchen/diner with LED dimmable bulbs.
I fitted the an eclipse 2 way dimmer and rocker switch the other side but somewhere there ia fault as the lights dont go out but i fitted everything as it was before with 2 dimmers but with GU10 standard bulbs.
On the 2 wat side i have an earth, a blue, then yellow and 4 red wires which has be confused and a brown link wire.
The other side is just yellow red and blue where i intend to just fit a rocker or should i get another dimmer there to make it work
Many thank sin advance
