I have 2 cabinet doors to hang just bog standard 22mm mdf panel
The first went on fine the second however is giving me grief
I'm using those flush hinges that don't need recesses.
The problem is the problem door once hung springs back when you close it
the hinges feel a bit tight as the door closes the other door is fine and shuts properly
The frame is square and plum I've checked and double checked that and I've also tried shimming the hinges but I can't seem to get it quite right
Can someone offer some advise
