It might just help you survive the testing!I planned to connect those when all in working order. Is it necessary just for testing though?
Are they dimmable bulbs?Just to confirm that it is a dimmer switch.
The switches control 2 lights but the bulbs are fine
Indeed.Many dimmer switches will not work in a normal 2 way circuit as they are not change over switches. They have three terminals. Live and Switched Live as in a normal ON OFF switch but the third terminal is a control input for use in "two way switching" The control input, sometimes called "slave" takes a control signal from the other "switch" which is not a switch but a remote controller.
