Best zone 1 downlighters
2 Aug 2007
Dear All,
Can people provide thoughts on some good quality Zone 1 downlighters.
I need ones with chrome bezesl which is not dimable or tiltable. They will very probably have LED bulbs.
Above them is a pitched roof cavity which will be insulated. I will not have access to the roof to install them.
Cheers
Paul
You must not cut holes in your lovely thermal layer.
What do you think is going to happen to all of your expensive heat?
Not if you are going to shag your thermal rating.
Is this a new construction, with building control viewing it?
That is a bit confusing but if you do not have access above the bath/shower ceiling then you cannot and will not be able to fit them.
yep cable, but I have a means of getting that into place. The size of the extension is very small
Do I take it that you're certain they will be in Zone 1? 2.25m about FFL is quite low for a ceiling - my SIL is nearly 2.03m tall.
But you cannot have holes in the insulation and you will not be able to cover the lights (with suitable enclosures) to ensure the insulation is intact.
ceiling is actually around 3m, I was just thinking zone 1, perhaps in error
sorry I'll be fitting them from below
The problem is that the insulation in the roof must go over the lights to comply with building regulations, and all downlights require a certain amount of free space around them to avoid overheating and failure.
This is usually acheived by the use of these: http://www.tlc-direct.co.uk/Products/JC94020.html or similar products, which obviously cannot be installed from below.
On reflection perhaps I was slightly unclear earlier, I can probably access the loft from the side but cannot crawl into the loft
Zone 1 only extends up to 2.25m above finished floor level (even if bath or shower tray is much higher that floor, which is daft!) - so it sounds as if your light would not be in any Zone.
