I've got some insurance contractors in doing up part of the house. There were some cracks in some of the walls, and they carved them out and filled them in. They have now painted over them. The areas where they filled in are visibly different to the main areas of the wall (at least, if you are looking under certain lights). To clarify, the paint across most the wall has a slight texture to it (not a deliberate thing, but just a slight stippling effect where the paint dried), however, over the areas that were filled the paint is totally flat.
I've had a read around, and I get the impression this might be because they didn't put primer on top of the filler. Could that have caused this? Would it have solved it?
Am I just being fussy, and should I just accept that after patching up cracks the wall will look imperfect unless it is skimmed?
If there is a way to fix it, now that it has already been painted, I would be happy to hear this.
