I have recently lined the HSL with 1400 grade lining paper and then painted over it with Dulux Trade Matt emulsion. After the first coat some seems were still slightly visible so filled with Red Devil OneTime and rubbed down slightly, and went over the filled areas with a rad roller. I've then painted the walls again with another 2 coats. The issue I now have is that there are fine hairline cracks appearing in some of the seems (filled ones and not filled!).
I'm guessing that each subsequent coat of paint has caused the edges to lift ever-so slightly resulting in the cracks appearing as the paint has dried. Indeed, the seems where I've used the filling feel slightly raised and are more noticeable.
I ensured the paper was butted up neatly with no gaps and pasted well (or not maybe?).
Is there anyway this can be rectified/saved?
Thanks in advance.
Thanks in advance.
