S/S surface mounting box >35mm for shaver socket
10 Jul 2008
Bath
I need a stainless steel, or possibly chrome, 2g surface box to house a shaver socket. Yes, I'd rather embed it in the wall too but it's not possible. Since its a shaver socket it needs to be deeper than 35mm I think. I've seen a couple of those.
Checked all of the obvious places and Google can't find me one
Anyone know where I can get one?
Thanks in advance.
thanks both
seems that there are several 35mm, but no 47 or >47 ones I can find so far
I am so sorry for trying to help somebody.
The description on the link clearly states
2 Gang 32mm Surface Wall Box - Chrome
If you think that is an incorrect description, then perhaps you might like to direct your pedantry at the supplier, or TLC, and not at me.
The description on the link clearly states 2 Gang 32mm Surface Wall Box - Chrome If you think that is an incorrect description, then perhaps you might like to direct your pedantry at the supplier, or TLC, and not at me.
As I've just posted, if you click on that link, the description you get is "32mm Deep White Surface Accessory Box with Chrome Surround" (in a slightly smaller font, just below the 'title' you correctly quote).
I know what it states, and as I said, I don't believe that is actually chrome, as in something proper made of metal.
Personally, I cannot stand that plastic fakery, and I know that others feel the same.
Maybe the OP also feels like that.
The 'surround' may perhaps be metal - it's described as a "32mm Deep White Surface Accessory Box with Chrome Surround".
I know what it says.
I invite you to look at the thickness of the walls - you can see better how thick they really are in the photo of the single-gang one:
I also invite you to look at the price, and consider how likely it is that somebody could fabricate a genuine solid metal surround in brass, or steel, chrome plate it, polish it, and fix it around the outside of a plastic pattress for that sort of money. And why they would do that rather than just make an all-metal box.
I checked with TLC.
It's coated plastic.
A Bicc razor is suddenly so attractive, perhaps made of the same quality plastic :lol:
Get the bolster out and bugger the expense !
DS
