What to do about reveals
14 Jan 2008
Staffordshire
Hello all :)
Next project is studding out the walls in a couple of rooms, insulating them, and reboarding.
I don't really want to remove the old reveals.
How would I finish the new boards up to the reveals, to enable this to happen?
Or, is it "impossible", and I should just chop the lot out, and start from bare brick?
Thanks in anticipation. :)
Is that unavoidable, or just easier for the plasterer following on?
Just trying to minimise disruption for me (really, for SWMBO)!
how much room have you on the reveals? if you are studding out over the existing plaster you could d&d the reveals
No room on the reveals, Steve - anything other than a feathering-in of a corner bead would eat too far onto the window frame.
So, the question basically is, can the insulated boards be run up to the corner, then beaded and feathered into the reveal, or is knocking the reveals off the only solution?
And if the feathering-in is an option, how close to the corner do I run the (wall) board up?
And thanks to those who took the time so far :)
I can't see that working it would be a botch job if you don't fancy chopping all the render off walls like rc said u could maybe chop out just the reveals to make room to d&d boards, other than that chop it all back like rc said
How thick is the plaster on the reveals? When you say you're studding out the walls, i'm assuming you're studding onto/over the old original plaster, rather than hacking all back to brick. If it was me doing it your way, the only plaster i WOULD remove carefuly, is the plaster on the reveals and soffit, take it back to brick/concrete lintel. By removing the plaster from the reveals etc, that has given you, hopefully enough depth to fix some plasterboard to the reveals/soffit when the time comes.
Right, here we go, this is what i'd do.
Measure and fix your studding to the main part of the wall, making sure you "start from the exposed brickwork of each reveal, and work away from them. Keep the edge of the battens plumb to the edge of the brickwork on each side of reveals, and the same with the batten along the lintel. Keep the batten horizontal and level/flush to the underside of the concrete lintel.
Fit the rest of the battens, insulation, plasterboard etc as per normal.
Once you have that all done, it's time for the reveals/soffits to be boarded. After removing the plaster from the soffit/reveals, you should now have enough depth for the plasterboard. The reveals and soffit will now also be wider too, because the wall has been battened and boarded out, so now, starting with the soffit, measure and cut a piece of plasterboard for the soffit, then fix it in place. You can use a grab adhesive, (sticks like st*t) or similar to bond the plasterboard in place, plus you can fix the plasterboard along the front by screwing into the batten that was fixed to the lintel. You can then do the same with the reveals on either side, (grab adhesive and screws into the timber studding) running down the side of the reveals. Bring the plasterboard on the reveals out flush to the corner of the wall/reveals. One you've done all that, it's just a matter of putting thin coat beads around the reveal/soffit, taping all the joints in the plasterboard, then you're ready for plastering. Hope you get my drift on all this. Remember, "fix the plasterboard to the reveals and soffit last", and good luck to ya. :wink:
If you do use a "grab adhesive", make sure you give the reveal brickwork/soffit lintel, a good dust down first.
if you havent got room to put boards on the reveals using d&d with plaster on you def wont have room for battens "and" board even after removing the plaster
He wont need to be using any battens at all on the reveals/soffit Steve. A fixed batten will run up the front face of the wall, on the edge of each reveal, plus a fixed batten running across the front face of the lintel/soffit. The plasterboard for the reveals and soffit will then be fixed with "sticks like sh*t" to the newly exposed brickwork on the reveal etc, and screws fitted to the battens running up either side of the reveals/ along front of lintel. With the plaster removed from the reveals/soffit, there should be plenty of room for the thickness of plasterboard.
misread your post
one thing i will say is that lintels are sometimes out of square you may have to adjust your batten accordingly to get it square and level also if its so far out of whack it will best to use drywall addy , 2 of my lintels were really bad i d&d one but still had to float it level the other one was twisted and i had to float it out by about an inch to squure it off before beading up
