- Joined
- 20 Dec 2014
- Messages
- 43
- Reaction score
- 0
- Country
Hi - first time poster, long time lurker! Have used this fori extensively recently for several diy guides, so thank you.
Currently I can only establish central heating in the house if I enable hot water. (I can have hot water without heating).
Initially, as it's an old house, I thought this was a limitation of my heating system (thinking it was semi-gravity / gravity fed).
However, after some recent reading up on the subject I have established that the system may have been converted by the previous owner when a Worcester Greentar RI boiler was installed in 2012.
The airing cupboard has a pump and a (new) mid position valve (receipt for March 2014 found in the house paperwork _ I moved in in November)).
The house has a British Gas 'Hive' receiver installed (not registered it) which can be used as an in-house heating controller if unregistered (I confirmed this with BG).
I beleive this to be wired incorrectly and have attached photo's of the set up behind the timer and behind the junction box in the airing cupboard along with the pump and mid position valve. I've also shown the wiring guide behind the Hive programmer (receiver) - is mine wired correctly.
Can anyone suggest some wiring 'fixes' that could be carried out by me to enable independent CH control?
