I see. In that case, what figures does one use? It would presumably be inappropriate to use 70°C thermoplastic figures (which would give 78A for buried 16mm² SWA), since they relate to a different material.You can't use XPLE figures unless the devices it's terminated onto are rated for 90°C connections.
I would think using the PVC figures would be a good place to start as they assume a maximum conductor operating temperature of 70°C, and I can't imagine the thermal insulating properties of PVC differs that much from XLPE.
I think you could probably use the adiabatic equation to work out the maximum CCC of XLPE conductors at 70°C if you really wanted to.
