D
Deleted member 174758
Sealing MDF cut edges isn't difficult, just time consuming. Sand the MDF working through the grits up to about P240 or better still P320 grit. The finer you sand the stuff the less the grain should raise when you apply the finish. If possible use a non water-based sealant if you can. I've used all sorts of stuff from oil-based undercoat to clear sanding sealer (basically blond dewaxed shellac flakes dissolved in methylated spirits - Zinnser BIN is quite similar). The first coat should be diluted with the appropriate solvent. Once it's dry denib it with a fine sanding paper and give it a second coat. Three coats should suffice. You can even use good quality spackle (drywall jointing compound), but like any water-based compound it will raise the grain of the MDF quite a lot and require a lot more work flatting back between coats
