Waterproofing doors that are overlooking the open sea
29 Dec 2014
Suffolk
I have just moved to a house at the back of a beach, fully exposed to the sea. There is a balcony on the first floor and when there is a southerly gale, and only in a southerly gale, water is forced under the doors to the balcony, despite my attempts to make them waterproof.
My next idea is to fit a removable horizontal board such as is used to prevent floods getting through openings in flood walls or on the doors of houses in flood areas.
My idea is not to make a waterproof seal but to provide shelter from the winds in gales and storms so that water is not forced under the doors.
The door is narrow both in width and depth.
I would welcome any advice as to whether I have a reasonable solution and if not please offer suggestions.
If I have a reasonable solution, what can I use as brackets to hold the board in place given that I have narrow frame.
Thanks all
Brendan
Any pics, does the door have a stepped threshold?, does it open inwards?
There are in fact double doors about 3 metres tall and each is a sealed double glazed unit with timber surround.
The doors open inwards.
There is a wooden striking plate (is this the correct term?) and the bottom of the doors protrude beyond it. There was a gap of approx 1/2 inch between the bottom of the door and the striking plate so I screwed a piece of timber approx 1/2 on top of the striking plate and planed it as necessary to allow doors to close and put brush like draft excluders on bottom of door.
This works fine in normal rain but with a gale from the south rain is driven in.
I have uploaded 3 pics. Hopefully there will be a link on this when published.
Brendan
http://www.stormguard.co.uk/products/SillsPartM/Sills.htm
Thanks for this link.
I am gob smacked at the variety.
Because of the size of these doors, I was hoping to find a solution that didn't involve taking the doors down and rehanging them.
I will try to work through them all and see whether I can find anything that can be fitted without taking down the doors.
Brendan
