We have a Combi Eco Range Main Boiler connected to a wireless thermostat (Salus make). The boiler is around 4.5 years old. The radiators in the house were not heating up after we came back from holiday. I tried bleeding the radiators but they seemed ok as there was no air coming out of radiators. I looked at the boiler and noticed that the central heating temperature control rotary switch was set to quite low temperature. I think I might have done this when I turned the boiler off before going for holiday. So I turned this switch to a higher temperature. Now the Radiators are all quite hot however the boiler seems to be not turning itself off. The thermostat temperature is above my set temperature, in fact the thermotstat does not show the icon indicating that the boiler is on. However if I see the boiler panel the central heating indicator as well as the burner on indicator both are on and Boiler seems to be continuously working. Can any body please help? thanks in advance
