But you don't accept that the supply figure is nominal, so how can all those different figures be right? Surely there is just one voltage which is right?
Very much the same here. I know that I'll come to regret 'getting involved' yet again, but if only you would stop going on about it, I think you could probably rest in the knowledge that many, perhaps most, of us actually agree with most of what you say about this issue - that it's basically daft and unhelpful to have this situation in which the bureaucratic 'nominal' supply voltage differs appreciably from the 'most common' supply voltage in the UK. I think that the only main difference between you and many of us is that we accept that we are, at least for the time being, stuck with this situation, and that absolutely nothing is to be gained by annoyingly 'going on about it'.Whenever I have measured it over the last 50 years it has been around 242v. I have never seen it below 237 or above 245V. I therefore think it is around 240V, certainly not 230V.
Indeed - but it doesn't really affect the generating stations - it's only at the level of the final transformer (from HV to LV) that the final supply voltage becomes relevant, and I was under the impression that there is already a significant amount of 'adjustability' (taps) available....So we did change to 230 volts but with British ingenuity the specification was change to include 240 volts as an acceptable over voltage on a 230 volt supply. This meant the UK generating stations didn't need to alter anything. they could run at 240 volts.
Hello Winston
The UK was designed to operate on 240 volts while Europe chose 230 volts for most of the land mass. There were a few exceptions. I seem to recall a hotel in Paris that had 100 volts, so long ago I can't remember the date.
Then Europe took over the UK and told us to change to 230 volts to be in line with every one else. So we did change to 230 volts but with British ingenuity the specification was change to include 240 volts as an acceptable over voltage on a 230 volt supply. This meant the UK generating stations didn't need to alter anything. they could run at 240 volts.
Does that help you understand why a NOMINAL 230 volt network is supplying 240 volts to almost all domestic places that use electricity in the UK
What I'm less convinced about is that there are 'no plans to reduce the UK supply voltage'. It would not surprise me if, very gradually, it is shifted closer to the stated 'nominal' - not the least because that would probably offer some benefits for the suppliers.
It was, but I think you'd get a lot more respect if you resisted responding to such bait and, like the rest of us, avoided repetition of things we've read so many times before (and which, as I said, many of us probably largely agree with).Noted, but I did not start this discussion again. It was AndyPRK with his comment.
If it were only that, then there would be less to moan about. However, that 'nominal voltage' has, at least hitherto, been used for virtually all (mainly safety-related) calculations specified in, say, BS7671 (and probably other regulations) - which leads to potential concerns if it is appreciably different from the actual voltage delivered. Come tomorrow, we expect to see published the first example of BS7671 effectively deviating from this use of nominal voltage for all calculations - and it might possibly be the first of many such changes.I don't think that Winston really understands what nominal voltage means. It is a number which the DNO can use to determine whether they are meeting their commitments.
I'm not so sure about (the first part) of that. As often discussed, in the presence of such wide permitted supply voltage variation, most of what is said about VD is pretty daft, but I'm not sure that there is anything in BS7671 which says that 'permitted voltage drops' are not allowed if they take the voltage at the end of the circuit down to below the permitted minimum supply voltage (2.16,2V), is there? Also, as westie often reminds us, supply voltage is apparently allowed to deviate outside of the range 216.2V-253V for 5% of the time!It is worth saying too, that the voltage supplied to a house has to be 4% higher than the minimum voltage permitted to allow for the voltage drop requirements of BS7671, but can never be higher than 253V.
Who or what says that? I've seen appliances labelled/rated/'speced' "220V", "230V", "240V", "220V-240V" and various things like that, but never one labelled/rated/'speced' "230V -6% +10%" or "216.2V - 253V" - have you?OK - so think of what I said as a challenge or question. An appliance manufacturer is required to ensure that their appliance works from -6% to +10%.I'm not so sure about (the first part) of that. As often discussed, in the presence of such wide permitted supply voltage variation, most of what is said about VD is pretty daft, but I'm not sure that there is anything in BS7671 which says that 'permitted voltage drops' are not allowed if they take the voltage at the end of the circuit down to below the permitted minimum supply voltage (2.16,2V), is there? Also, as westie often reminds us, supply voltage is apparently allowed to deviate outside of the range 216.2V-253V for 5% of the time!
I'm really not sure where your 4% comes from (I obviously realise that 10-6=4, but I'm not sure what that's got to do with anythingA DNO is required to supply exactly the same voltage to the supply terminals of the house. So how do we account for the remaining 4%? Whose problem is that?
