When ever you buy a plug in light/lamp, they always come with a 3 amp fuse in the plug?
Now as most of these lamps will be drawing under 230 watts, would it not be more safer to have a 1 amp fuse in the plug instead?
And while the cable and lamp holders of most lamps is rated at least 3 amps and likely the reason for the 3 amp fuse in the plug, is it not best practice to use the lowest fuse ratting suitable?
