Unless I'm misunderstanding, something doesn't seem to add up here. I thought you said that with no thermostat at all (with the backplate of the new one wired, but the front part not plugged in), the boiler didn't fire up. If that is the case, I doubt that it is damage to the programmer or boiler that is making it come on when it shouldn't when you re-fit the old thermostat. Am I misunderstanding?Further worrying development...Now even when my programmer is set for the heating to be constantly off and I have the old Satchwell TLX2259 re fitted, when it starts calling for heat, the boiler now fires up the heating even though it should not as I have effectively turned it off using the programmer ...Have I damaged the programmer or the boiler as well?
