Very many thanks to all responders for the replies posted. I hope the info will benefit other forum users.
That sounds promising - as I said, that was one of the possible outcomes if you found a "decent/reasonable human being" to talk to.I have just got off the phone to the LABC. At first the girl wanted to charge £275 for a new building notice but then she put me through to an actual inspector. After I explained the matter he said he would send me a regularisation form which effectively retrospectively updates the Building Notice. Then the LABC will send an electrician to do an inspection. I think I am very lucky. Maybe the LABC is like the Inland Revenue - not so bad when you talk to them![]()
That's obviously good.Hi JohnW2 - thats right but it is not costing a penny more. As I said Vive le Building Inspectors (in North Herts)![]()
Electrical work in kitchens is actually no longer notifiable, per se - so is not notifiable unless it is for other reasons (e.g. new circuits). Shower rooms are, indeed "special locations" but electrical work in them is only notifiable if within the prescribed 'zones' (essentially, within 600mm of a bath/shower and less than 2.25mm above floor level) - hence none of the electrical work is notifiable in some bathrooms. However, an electric shower obviously would be 'within zones', and hence notifiable.Actually it seems a reasonable solution. The original Building Notice electrical works about notifiable work should have been filled in because the planning application included a shower room and kitchen and works in these "special areas" are notifiable.
There has been a lot of discussion, here and elsewhere, about what constitutes a 'new circuit' (which would be notifiable) but I'm sure that some would argue that if it is using a pre-existing feed, then it amounts to modification and/or extension of an 'existing circuit', and therefore is not notifiable.Hi John - this is news to me... maybe good news. ... The extension is a replacement and the electrical works (lighting/sockets) use the original feeds from the house. I thought they would be considered new circuits.
Are you saying that the cooker is on a 'new circuit', and hence needs notification for that reason? Do I take it that there is no electric shower - since, as I said, that would inevitably be 'within bathroom zones', and hence notifiable?If they are not and therefore not notifiable then the only item that would need inspection is the new electric cooker (the shower room extractor fan is much more than 600mm from shower etc).
I'm not sure what attitiude LABCs take to 'non-notifiable electrical work' which is part of a project in which they already have an interest but, in terms of 'notifiability', per se, it would certainly be possible to build an extension which involved no 'notifiable electrical work' if all the electrics in the extension were achieved by 'extending existing circuits'.Can it be that I can build an extension with new lighting and socketry wiring and not have to present some sort of certificate of approval?
If it was a new circuit, hence notifiable, unless it was 'self-certified' by the electrician who did it, it would need to be notified to LABC in the usual way.Also the cooker was connected by a Part P registered electrician.
Fair enough. When they send out sub-contracted electricians to undertake inspections, they often 'pass on' that electrician's fee. Do I take it that you have been assured that this will not happen?So whilst I could argue with the inspector that the work is an extension of an existing circuit I would rather accept his generous offer to send an LABC approved electrician to inspect the lot!
Yes, in terms of common sense, I would certainly call that a 'new circuit' - although I'm sure that there are those out there who would try to argue that it was a 'modification' to the existing circuitYes the cooker is a new circuit because I stripped out the old 6mm cable and clipped a new 10mm cable to the underside of the floor joists. I left one tail at the consumer unit and the other at a cooker switch. The electrician stripped the old 6mm tail from the CU and connected 10mm. He also swopped out the 32A mcb for a 50A (the new cooker is theoretically 14,8KW with every thing on max). He then connected cooker end to a cooker switch and outlet I installed.
Hmmmm!On the other side I had a young guy (studying but not yet qualified) that charged £120 to install a mains bond earth from kitchen copper pipe to electricity supplier earth!
What was this copper pipe?On the other side I had a young guy (studying but not yet qualified) that charged £120 to install a mains bond earth from kitchen copper pipe to electricity supplier earth!
As you say, only time will tell.Hi John, The LABC accepted my claim that it was a form filling oversight and agreed to retrospectively modify the Building Notice i.e. its as if I had filled in the electrical works section on the original building notice form. Whether I would have paid a higher fee originally is a moot point. No mention of an additional fee was made so I am not expecting to pay extra. However, I am waiting for a "regularisation" form to fill in and that may contain a nasty surprise.
There are, fortunately, very few tragedies - there are less domestic deaths in the UK due to electricity than due to DIY use of ladders, power tools etc. and, of course, many/most of what few electrical deaths there are may not have anything to do with poor DIY work. However, I obviously would not suggest that as a reason or excuse for complacency. The introduction of the concept of notifiable electrical work in 2005 was, of course, meant to be a step towards achieving the oversight you would like, but the relaxations (in England, not Wales) in notification requirements in 2013 turned the whole thing into little more than a joke. There is now very little electrical work which remains notifiable (in England).On the subject of arguing whether a circuit is new or not I think DIYer's should get expert approval of electrical works. I can imagine that pride, stubbornness and macho attitudes have caused a fair share of tragedies.
