I don't normally do any cement work if the temp is going to dip below 5degrees in the next 3 days. If I really must then Ill add some frostproofer and use a hessian sheet, but I still wouldn't do the work if the temp was likely to fall below 0degrees. The British winter is usually wet and windy rather than cold and icy, so it's unlikely that any freezing weather will last for long, hence why I put off cement work for a few days or a week until conditions improve.
That's just how I do things, based on my experience. I have had to redo a verge after the water in the cement froze and caused it to crumble, so a lesson learned for me.
