- Joined
- 27 Jan 2008
- Messages
- 28,738
- Reaction score
- 3,508
- Location
- Country
The lecture seemed to say drilling holes in beams will still be OK and this will hold the cables away from firemen.
Will they make these
Even when fitting metal tray and trunking I used plastic RAWL plugs will we need to use these
Fitting a LAN or speaker cable over a door I would squirt a thin line of silicon sealant and it necessary stick the wires to it with insulation tape until set. That has all gone now metal cable ties rule OK. But a plastic frame to door even if metal behind it what ever we use it will not hold the cable once that plastic melts. There may be wood behind the plaster but the plaster edge would crumble away once the plastic frame has melted.
With some 25mm x 16mm mini trunking we will need some clips to retain the cables once trunking has melted fitting these
