G
Good day to all, A solution for Replacing 6ft x 6ft fence panels @ approx 17kg up to 33kg and gravel boards @ 49kg.
How many people have struggled to replace the above panels and gravel boards.
The problem is getting the height to slot the panel or gravel board in, you need approx 6ft 6'' up to 7ft to ensure an easy fit
The solution is ! an ITEM that enables one person either Male or Female to lift from ground level minimizing manual handling to a safe controllable level, the Item can be erected in less than 2 mins and very easy to use, and operates in 10 to 15mph winds, the ITEM can be used on un even ground, where bushes hamper access, it even operates in most places where trees block access. One handed operation to lift the panel or gravel board and the other hand to guide the panel or gravel board into the slots on the posts
you can operate the ITEM and get the height of up to 8ft which is sufficient in 99.9% of gardens, it will not operate where two conservatories are very close together.
The ITEM enables you to lift the panels or gravel boards from your side of the fence should you have unco-operative neighbours, the ITEM will lift up to 75kg but certified to 150kg.
Wouldn't life be a little easier if we all had one of these ITEMS.
Many thanks all ( Uk Inventor )
