I'm adding an insulation at the first floor of my house which is made of timber and surround by roof tiles. It doesn't have an insulation at all right now and I'm wondering if it's worth adding the bubble foil insulation between kingspan 150mm and plasterboard.
Wall sections:
1. external roof tiles
2. breathable gap from the cold side
3. kingspan foil insulation between the rafters - first layer of kingspan boards
4. kingspan foil insulation - second layer of the kingspand boards
5. aluminium bubble foil insulation
6. battening - breathable gap, DO I NEED THIS GAP HERE?
7. vapour plasterboard - should I use non vapour instead if aluminium foil insulation is used?
8. gypsum
I'm wondering if anyone would have an idea of:
- If I should have the battening between aluminium bubble foil insulation?
- If I use the aluminium bubble foil insulation, should I then still use the vapour plasterboard?
Thanks in advance
Wall sections:
8. gypsum
Thanks in advance
