Recently replaced some bedroom downlights with led down lights. Everything worked ok, but we had an old dimmer and it was causing flickering and buzzing.
So, changed it today to a varilight led dimmer. Everything works much better flickering and buzzing wise but I think I have wired something up slightly wrongly.
Its a 2 way switch. There is a simple on off switch and then the dimmer.
Now, you have to have the on off switch in the on position for the dimmer switch to work. The dimmer then turns on and off fine. But if the on off switch is set to off, the dimmer does nothing. Its all useable but will be very annoying at times.
Have a wired up something the wrong way around or do I have a lose connection? Its a bit tight behind the switch, which makes things awkward.
Hope that makes sense.
