If that don't work, then you apply for a certificate of lawfulness.
But wouldn't it have had to be permitted development in the first place for the council to be able to give a certificate?
As far as I was aware, you cannot apply for an LDC for a development that would have only been permissible under the NCS, only for the standard PD rules.If that don't work, then you apply for a certificate of lawfulness.
The extension is permitted development under the new rules.
But otherwise a LDC is used when existing development is in breach of planning regulations, instead of a planning permission application.
Is there anything stopping her from saying it was built more than 4 years ago?
They have had the house for 5.
It can't be, unless a prior notification has been sent to the council and the council has then notified the neighbours and no neighbour has objected within the 21-day period. Only then would it be permitted development.
If the development would be permitted development, whether the notification process was followed or not, then it would be deemed lawful on any appeal. The council would be bound to grant a LDC.
LDC's are used for development, including that done under permitted development (old rules) so I can't see why it can't be used for the new rules. Is there anything in the legislation specifically preventing this?
No, and she might get away with it. But if the buyer/solicitor then asked her to get a certificate from the council, she would have to prove that it was built more than 4 years ago.
But it would never have been permitted development in the first place because the procedure for the new rules was not followed - ie they did not notify the council.
The development did conform to the PD requirements, and so if an application was made at the time then it would have been determined as PD.
