I admire you care to follow the law. It is a shame The Electricity at Work Regulations 1989 don't hold the same weight in your eyes by given incompetent people advice on how to do electrical works.
I am talking about some of the advice you have given to people who clearly could hurt themselves. Reading through your posts is alarming. So alarming that I would consider reporting them if they continue before someone gets seriously hurt.
Open to interpretation but most in the industry would consider the moment someone begins WORKING on a circuit they are in effect creating a place of work.
here are two photos. Not very clear in first picture but there is a conduit in the wall when cable exits garage wall. there are no marking on cable for me to check cable size.
If it was me I would install an IP67 rated box with fixed base connectors over this cable. From that box install an SWA cable (3 core / 2.5mm) to a convienient socket in the house. The SWA should be glanded with CW glands and the SWA earthed.
I would advise a qualified electrician to complete the final connections and test to ensure you have a safe installation.
Does your shed have any extraneous conductive parts? This could change things.
Can i install an outdoor ip66 socket which is fed from another socket using a plug! I have socket on inside of prefabricated garage. I want to install one on outside of wall for lawnmower
So I have a small run of cable already drilled through garage wall so was wondering if I can use this.
That cable is not suitable for use outside, so the easiest option is to put the outdoor socket where the cable exits the wall with the cable into the back of the socket.
At the other end, T&E isn't ideal to fit into a plug, but plenty of people have done it.
If you want the cable to be exposed outside, then it would be better replaced with some black rubber flex, this would also be better to fit into the plug inside the garage.
The work is not notifiable, and yes, you can do it.
You do not need another RCD if your consumer unit already has one.
It's what's inside the garage which matters. Is there any metalwork inside which does, or may, be in contact with the soil below?
inside of garage has metalwork to support the roof. i can't confirm either way of confirmation as the pre-fab garage is seating on a concrete foundation. thanks
I don't know, but I have a feeling that it might be, in the case of a tradesman/ whatever who is working in a customer's premises. After all, for many such people, their 'workplace' is always some customer's / client's premises.
However, the whole issue is clearly irreleavnt to the matter of notification!
