Hello again
I'm about to install this kiln (with help from an electrician). I need to buy a suitable isolator to fit adjacent to the kiln. I was looking at this:
http://www.toolstation.com/shop/Ele...essories/sd3080/Rotary+Isolator+4+Pole/p70254
but I notice that though 63A it's only 30 kW, and my kiln is 47.7 kW. I assume therefore that it's not suitable. It's the biggest that Toolstation do. Could someone kindly point me to what I need?
Richard
You need to have a serious look at your requirements then. I suggest talk to your electrician. 47KW??? are you sure????
47KW is more than 200amps and that is twice as much as the feed into your house……….!!!!!
EDIT. I dont want to read back over a hundred posts, but I rather think that you meant 47.7AMPS
If so, when i went to school, 47.7 was smaller than 63, so the Toolstation isolator would be OK.
