I'm planning an outdoor gazebo with concrete filled brick pillars (450 x 450) and a clay tiled roof and I'm struggling to work out what beam size I need for the spans between the pillars.
The span between the pillars are 4400 so allowing a 150 bearing (on 3 engineering bricks) the steel size would be 4700 - around the opening of a double garage really.
So far, I've worked out that the roof weight is 3100kg, so there would be a UDL of 1550kg along one steel and then a point load of 775kg (each roof gable ends supporting the ridge beam).
I have formulas from Chudleys but I'm running round in circles pumping out figures that have no meaning.
I'd read from a BC guide (san't get my hands on it now) that a 5m span 178x102x19 UB can take the weight of a 2.4m block wall - so even with a 14kg block that's a UDL of nearly 1700kg.
Would this beam be OK?
