LED driver question
14 May 2007
Hi all,
I have a question around wiring an LED driver.
I have some LED strip lights which I would like to use in a bedroom for some nice diffused lighting.
The drivers here are the ones i plan to use
https://www.led-lighthouse.co.uk/le...-well-100-watt-led-driver-24v-ip67-lpv-100-24
I would normally expect this type of driver to be wired to a fused spur.
In the bedroom I dont want to have a fused spur; is there any way to wire these to a normal plug to use in a plug socket?
Stu
I'm sure it will work fine if you just fit a regular plug to it.
The only issue is that it appears to have unsheathed wires. I think that to be compliant it would need to be fitted inside an enclosure, and those wires connected to a sheathed flex, with strain relief of some sort.
Where exactly do you intend to put it?
(Similar drivers that do have sheathed mains wires are available.)
It is not a driver it is a 24 volt power supply the voltage is fixed not the current. With a driver it will give something like 320 mA 0 ~ 40 volt the amps is fixed not the volts.
You may require a 24 volt power supply, many manufacturers seem to label power supplies as drivers when they are not, so you have to be careful. Often the driver is built into the bulb and you do need a power supply, but be wary and read the spec.
How on earth can permanently installed lighting in any way be better plugged in than connected via an FCU?
( courtery of Google translate Chinese to English )
This page can not be found
The page you are looking for might have been removed , it may be its name has been changed , or is temporarily unavailable.
Try the following actions:
Make sure the spelling and format in the browser's address bar displays the correct Web site address .
If you press the link to reach this page , please contact the system administrator to inform them that this link is malformed.
Click the [ Previous ] button to try another link.
HTTP Error 404 - File or directory not found .
Internet Information Services (IIS)
Technical Information ( for technical support personnel )
Move Microsoft Product Support Services , and the words HTTP and 404 relating to the search.
Open [IIS Help] ( You can choose from " IIS Administrator (inetmgr) " access) , and search the name to " set the platform ", " general system management " and " About Custom Error Messages " topic.
The HTTP 404 was a give away to what it said. But 100W on LED's at 24 volt = 4.16A that's rather high for LED's normally around the 320 mA personally I would not want to run 12 parallel circuits as if one blows it could overload the rest and it would seem it is voltage regulated anyway not current regulated. At typical 320 mA and typical 3 volt for white LED that's around 100 LED's that seems some what over kill.
If it were 12 volt regulated then likely designed for replacements for quartz halogen spot lights but at 24 volt I question what it will power. I do hate mislabelling be it calling 12 volt "low voltage" or power supplies "drivers" it seems however common with the lighting industry.
The light strip itself will be attached to the back of a tall chest of drawers, so i would attach the driver to the bottom of the back of the chest of drawers
Really? Can you give more details please; these LED strips need to be soldered on to the drivers as well so would need to be something that allows me to do that
Thats a different question and I never said it was better.
The lights will be fixed to a piece of furniture which will move on occasion for decorating and such likes. therefore it would be easier to have something that plugs in.
I already have the same LED strip installed in the kitchen with these drivers ; the drivers and strips etc were all supplied from the same company (LED lighthouse) and they all work fine :)
Ah - OK - fair enough.
It was the way you said "In the bedroom I dont want to have a fused spur" as if it were some kind of aesthetic objection....
