Hi all – can any body please help?
Had Building Control organised electrical inspection recently on an extension I built.
It came back with “no RCD protection on lighting circuit” and earth cables in switches not connected (I had heat shrunk sleeving over the ends intending to get choc blocks – then forgot).
The inspection passed the other wiring (sockets, cooker, extractor hood) all of which go back to the same Wylex CU.
The lighting circuit is based on twin and earth 1.5mm cable with plastic switch/back boxes. I have had bulbs fail and the MCB trips.
I have now terminated earth cables in single switches with choc blocks and in 2/3 gang switches I have connected the earth cables via choc block.
Does RCD protection require all earthing to be connected? Would floating earth leads in switches cause “no RCD protection on lighting circuit”?
If not - any other suggestions?
Many thanks
Many thanks
