Afternoon all,
My tiled roof consists of the following laters (looking from the bedroom ceiling up:
lath+plaster, old squashed mineral wool/glass, wooden floor... and then the attic space followed by joists + tiles (with plenty of bits of daylight in between the tiles!)
I want to insulate this a bit better: along the lines of:
waterproof sheet run around and between each joist, then put a layer of 50mm or 60mm kingspan or similar.
Floor side, take off the wooden floor, and take out the mineral wool, same 50mm or 60mm of kingspan or similar, then put the wooden floor back.
Will rewire the light wires so they run in the cavity between the insulation and the wooden floor back, drill a gap of say 2.5cm though to then push the wires back through for light fittings/switches.
Foil back or straight foam better?
Sound ok? (more concerned re the plastic and insulation on the joist side with damp)
Looking to get insulation from a seconds company - mismarked/slightly off size.
