Then ur installer fooked up
So you've had the plumber back, but you still don't have a fill loop?
This post reminds me of three monkeys, only there is a slight deviation of theme
One monkey with hands on ears hears no evil. Poster wants info but only what he wants to hear
Speak no evil. Poster speaks volumes
See no evil. Poster fails to see fact either. Filling loop MUST be there, how else is the boiler to be pressurised
6 pages of accusations and suspicions, negativity and belief TV programmes he speaks of are factual
OP: You said you were away on business? What business would that be? I would like to spend an hour with you discussing trhe possibility of placing a £250 order, most of which is overhead.
Poster wants to hear info but only what HE wants to hear.
I do have a loop which goes from the middle of that cold water pipe, attached just above a tube marked "SESI", then looping across to another pipe.
Can we have a photo?
The existence of a secondary filling loop on the pipework doesn't change the fact that the boiler's built in filling loop is missing. Did your plumber fit something to the back of the service valve that was changed? NRV & blank maybe? If not you will get very wet if it gets turned. I guess he didn't fit the grey plastic tap that goes on the valve?
normally the heating circuit end has one incorporated in the non return valve!
