Just wondering what code the following would give on an ECIR and if there is any 'real' concern in terms of electrical safety?
1) CU is 4 way and all circuits (lighting, sockets, shower and cooker) are covered by RCD on the main insolation switch. I gather this is because it is a TT supply. No other RCD's, just MCB's.
2) From the CU, an earth goes to the gas meter, a separate earth goes from the CUT to an earth stake and then an earth goes from the earth stake to the water stop cock.
3) The earth wires are about 6mm if not slightly less.
Wiring is from about 1997 and its for a downstarirs flat, with most cables under the floorboards, laying loose and not clipped.
Many thanks
Many thanks
