Be fair - grey is a fairly neutral colour.
and there could be 50 shades of it.......Be fair - grey is a fairly neutral colour.
No, you would stop and not continue until you had got access to the terminations of the existing cable.
Guessing does not count as exercising reasonable skill and care.
Guessing does not count as good workmanship.
Guessing is not something which is done by skilled or instructed persons.
Guessing is not allowed.
Is that where lies the belief that Grey is Neutral?
May I venture to suggest that anyone who is likely to cut blindy into a cable without verifying that it's the cable he wants and that it's dead (unless shutting off the entire installation) is probably not going to be too familiar with the nuances of whether black or grey is the "preferred" color with the new cable anyway?Of course your right bAS, but I was talking about a unlikely hypothetical situation where a DIY'er might cut into a cable without accessing either end of the terminations.
It's used for neutral over here, along with the more common white.Be fair - grey is a fairly neutral colour.
For identifying the three phases in a three-phase system, yes. But we're not talking about three phases. We're talking about two lives of a single-phase system, one of which is switched, plus a neutral. Under both the old and the new scheme you end up with two conductors which are the wrong color without reidentifying them at the terminations.Red was replaced with brown
Yellow was replaced with black
Blue was replaced with grey
What happens when you get a screw between Brown and Black your way?Brown
Black
Bare earth
Grey
Black
Bare earth
Grey
Question: How would you use a new brown/black/grey cable to run a 3-wire d.c. circuit?So, in conclusion, there is nothing to suggest a harmonised black is the best colour to use as a neutral in a 3 core+E cable, so only silly people would choose to do this.
And on which wire of the brown/black/grey cable would you be likely to place it?By first obtaining some blue sleeving.
As would most people, I would think. It would seem somewhat perverse to do otherwise when you already have two out of the three wires the right color for the application.Black.
