I have a double Panel radiator fitted in the hall, my problem is the front panel does not get that hot compared to the rear/wall side panel.. I have bleed the radiator and still the same? I was thinking of unscrewing the end cap opposite end from bleed valve a little to see if this helps, maybe airs trapped at this end? If not is my new radiator fooked?
http://www.screwfix.com/p/moretti-s...-radiator-charcoal-600-x-1400mm-6164btu/13172
