I'd like to put a heater in our airing cupboard and would appreciate hearing your thoughts. It's just a small cupboard on the landing that probably used to hold the boiler (the house had a combi boiler in the kitchen when we bought it). The cupboard is approx 60cm by 80cm by 160cm.
I plan to run a fused spur off the ring main and use a 500w convector heater from Dimplex (recommended for airing cupboards).
- Would 3 core 2.5 mm cable be okay?
- Does it matter if you use flexible or non-flexible cable?
- Is a 3 amp fuse enough? (500w = 2.17 amp)
- There's a junction box in the loft for the four bathroom spot lights and extractor fan. The airing cupboard is outside the bathroom so the junction box is in a good location. How can I tell if it's okay to take a spur from that junction box? If it's not okay, how can I be sure whether wires are part of the ring main or part of a spur? I'm new to the house and it's the first time I've looked at the electrics, I haven't got it mapped out in my head.
- will an electrician need to sign off the work?
- is there anything else I need to think about?
Thanks! I'm new to electrics but you've got to start somewhere. I just want to make sure I understand it properly before I attempt anything.
