Now define what "changing the configuration of a circuit" means!Changing the configuration of a circuit might though.
Some may take that view, but I very much doubt that it would really be within the 'spirit of the intention'! I would suspect that the real intent was for work to be notifiable if it required new 'design'. Adding sockets/lights/spurs/branches etc. usually would not require that, but if the OPD, cable CSA or design current were changed, 'design' would be necessary - hence I suspect that's what they really had in their minds.Ah, following you now. So we could, perhaps, take "new circuit" to mean that every single part of the wiring forming the branch circuit as it ends up is new, and if any part of the original wiring of that branch circuit (including fuse or MCB) was there to begin with, it's merely an altered circuit, not a new one.
I can give you some examples: changing a ring final into 2 radials; or combining two radials into a ring.Now define what "changing the configuration of a circuit" means!![]()
Agreed!Some may take that view, but I very much doubt that it would really be within the 'spirit of the intention'!
Hmmm... I'm not sure about that. If, for example, you were about to add 500 or 600W of lighting to a circuit, wouldn't you do some sort of "design" work, if only in your head, to determine whether or not you thought the existing circuit could cope with that extra load? Or if you were about to add a couple of wall-mounted panel convector heaters to an existing 20A radial circuit feeding sockets, wouldn't you do similar calculations, at least roughly? But I don't think either one of us would in any way believe that the regulations intended those to be classed as "new circuits."I would suspect that the real intent was for work to be notifiable if it required new 'design'. Adding sockets/lights/spurs/branches etc. usually would not require that, but if the OPD, cable CSA or design current were changed, 'design' would be necessary - hence I suspect that's what they really had in their minds.
Indeed. But there are numerous scenarios we could (and have) hashed out with regard to notifiable vs. non-notifiable work, both with the new "simplified" rules and especially with the earlier more extensive rules, which would go against common sense, at least as we might see it.In common sense terms, it would be ridiculous to say that a circuit was not a 'new circuit' because it was re-using just one or two components (OPD, socket, switch, a bit of cable or whatever) that was part of a pre-existing circuit.
The problem there is that the people who wrote the regulations think that installing a CU is notifiable.It's also clear that if you fit a new consumer unit in place of something which was not a consumer unit, then it's not notifiable since you're merely fitting a new consumer unit, not replacing one.
Why are they? What makes them new circuits and not just existing circuits transferred to some new type of distribution board?Also, if you fit a new consumer unit in place of something which was not a consumer unit then the final circuits are new.
Apologies - I worded the bit about design current very badly. What I meant, and should have written, was something like "if the design current had risen to a figure which would not have been acceptable for the original circuit" (again implying that a change in OPD and/or cable would be required).Hmmm... I'm not sure about that. If, for example, you were about to add 500 or 600W of lighting to a circuit, wouldn't you do some sort of "design" work, if only in your head, to determine whether or not you thought the existing circuit could cope with that extra load? Or if you were about to add a couple of wall-mounted panel convector heaters to an existing 20A radial circuit feeding sockets, wouldn't you do similar calculations, at least roughly? But I don't think either one of us would in any way believe that the regulations intended those to be classed as "new circuits.".I would suspect that the real intent was for work to be notifiable if it required new 'design'. Adding sockets/lights/spurs/branches etc. usually would not require that, but if the OPD, cable CSA or design current were changed, 'design' would be necessary - hence I suspect that's what they really had in their minds.
OrWhy are they? What makes them new circuits and not just existing circuits transferred to some new type of distribution board?Also, if you fit a new consumer unit in place of something which was not a consumer unit then the final circuits are new.
Thanks - That would make more sense, although obviously the wording in the regulations could have suggested such if that was the intent.Apologies - I worded the bit about design current very badly. What I meant, and should have written, was something like "if the design current had risen to a figure which would not have been acceptable for the original circuit" (again implying that a change in OPD and/or cable would be required).
Well, yes, but it's obviously 'the law' (the Building Regs) which specify that installation of a 'new circuit' is notifiable, and that legislation is total silent in respect to any criteria for deciding whether or not something is a 'new circuit'. It obviously had an 'intended meaning' (maybe a meaning that they regarded as "obvious"!) in the mind(s) of the person(s) who wrote it, but .....!!Thanks - That would make more sense, although obviously the wording in the regulations could have suggested such if that was the intent.Apologies - I worded the bit about design current very badly. What I meant, and should have written, was something like "if the design current had risen to a figure which would not have been acceptable for the original circuit" (again implying that a change in OPD and/or cable would be required).
There is surely 'altered' and 'altered'? If I removed all of an existing circuit and replaced it with one which had different rating of OPD (in the same CU 'slot' that had been occupied by the OPD of the previous circuit), different sized cable, different cable routing, configuration and length, and different accessories, would you seriously suggest that all one had done was 'altered an existing circuit'? We don't know exactly what was the 'intent' as to where the line should be drawn, but what I've just described surely goes over that line?surely if not specified otherwise, "new" means "not existing before" which is quite different from "altered."
But what if you did it in stages?If I removed all of an existing circuit and replaced it with one which had different rating of OPD (in the same CU 'slot' that had been occupied by the OPD of the previous circuit), different sized cable, different cable routing, configuration and length, and different accessories, would you seriously suggest that all one had done was 'altered an existing circuit'?
We can try, but the problem is that common sense and Whitehall bureaucrats writing these ambiguous regulations don't really go well together!In the absence of any proper definitions, I think all we can do is to attempt to apply some common sense.
You would then have created/contrived an even "greyer" situation, about which opinions would obviously vary!But what if you did it in stages?
Not that you can trust a single word they tell you since they have a vested interest, but have any local authorities yet expressed any specific opinion as to what they consider a "new circuit" to be? (Or a "consumer unit" for that matter.)You would then have created/contrived an even "greyer" situation, about which opinions would obviously vary!
